Zum Hauptinhalt wechseln
Device repair and information for HP's line of Pavilion 15" laptop computers.
How to solve 5 long and 3 short caps lock blink?
My laptop is model is HP Pavilion 15 ( au172tx ) and not turning on. It shows 5 long and 3 short caps lock blink error. Please help me if anyone know a solution for this issue. Thank you. Does anyone have faced this kind of issue ?
Ist dies eine gute Frage?
Bewertung 10
9 Kommentare
5time caps lock bilinking but no on display
von
tengo una laptop hp stream 14 cb111wm q enciende el led del caps lock 5 veces largas y 3 cortas pero no encuentro como reparar la enciendes y no da video pero cuando la apagas se ve un pantallazo negro como q apago ayuda por favor
von
HP Pavilion 15 Series caps lock blinking 7times long and 4 times short please help me any one
von
I have the same problem whet my "omen hp"
von
I'm looking to do a power reset, so I've opened up the device, but where is the coin battery?
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi @anjuwa
A 5:3 codes is a systemboard problem.
This is what HP says:
The red light blinks five times, and then three, short white light blinks
This condition indicates the embedded controller cannot reach the BIOS within the established time limit.
Remove all accessory devices from the notebook and try to start it.
Contact HP service.
Try a power refresh to hopefully get it working again.
i). Switch off the laptop and disconnect the charger from the laptop if connected.
ii). Disassemble the laptop and disconnect the battery from the systemboard. You don’t have to remove the battery, simply disconnect it.
iii) Remove the RTC coin cell battery from the systemboard. Remember its orientation for when you reinsert it later. Usually it is +ve on top as marked on the battery
Here’s the maintenance and service guide for the laptop, taken from this webpage. This details the necessary pre-requisite steps to access and remove the components. The RTC battery is not mentioned but when you have the laptop open and can access the systemboard, you will see it.
iv). Press and hold the laptop’s Power on button for a full 30 seconds and then release it. This will restore the BIOS to its default settings, in case a corrupted BIOS was the cause of the problem.
v). Reinsert the RTC coin cell battery, (remember orientation), reconnect the main battery, re-assemble the laptop, connect the charger and turn on the laptop and check.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset. Once the D&T have been adjusted, the message won’t appear the next time the laptop is started.
If the error code is still there, then commiserations, as there is a problem on the systemboard. You may either have to find the schematics for the systemboard and try to work out what’s wrong or contact a reputable, professional laptop repair service.
War diese Antwort hilfreich?
Bewertung 6
7 Kommentare:
Hi @jayeff
your solution helped me as well! Many thanks for your effort in replying and supporting, here. Very appreciated.
(HP Spectre X360)
von
i did all and yet it is not working
von
My hp laptop ( da-1058tu) doesn't have an RTC battery on the motherboard, I have double-checked it, how to replace the CMOS battery if the laptop doesn't have one on it?
von
@vigneshrg0
The "cmos" battery voltage is supplied by the main battery
Try disconnecting the charger (if connected), removing the battery from the systemboard and then holding the power button operated for 30 seconds. and release it.
Here's the maintenance and service guide taken from the support page for your model.
Go to p.41 to view the procedure to remove the battery
Reconnect the battery, re-assemble the laptop, reconnect the charger and check if it turns on OK.
von
tengo una laptop hp stream 14 cb111wm q enciende el led del caps lock 5 veces largas y 3 cortas pero no encuentro como reparar la enciendes y no da video pero cuando la apagas se ve un pantallazo negro como q apago y no tiene cmos ni pila ayuda plis
von
2 weitere Kommentare anzeigen
Hi @faithsmith
Try a power refresh and see if that works but it may not.
Disconnect the charger from the laptop (if connected) and then open the laptop and remove the battery.
Here's the maintenance and service guide for your laptop.
Go to p.32 to view the procedure to remove the battery.
Once it is removed, press and hold the laptop's power button for a full 30 seconds and then release it.
Reinstall the battery, re assemble the laptop, connect the charger and check if it now turns on OK.
If it still doesn't work, then there's a problem on the motherboard and further testing using the schematics for the motherboard would be needed to find out what's wrong.
Bewertung 1
Step 1: Disconnect and reset your memory module
  • First, remove the protective casing that protects your memory module located on the backside.
  • Now, take out the memory sticks and put them back.
  • Try switching on the system. If it works properly, then you have solved your problem.
Step 2: Perform a Windows Memory Diagnostics Test
While the problem may appear to be resolved by resetting the memory sticks, it's worth running a diagnostic test to determine if your RAM is defective.
  • Click the Start button, and then type Windows Memory Diagnostic.
  • Click on it. The new option box will now open. Click on "Restart now to check for problems"
  • Windows will restart, and run the test to determine if there is a problem with your RAM. It will then automatically restart the system after the test is complete.
  • Once it has restarted, wait for the message box to display the result.
  • Your memory sticks will be fine if there are no errors.
  • If it turns out that one of your memory sticks is defective, you can replace it.
Answer Source - hp caps lock blinking codes
Bewertung 0
2 Kommentare:
Visit a technicial yo flash your bios as the last option
von
I have a hp model number 14-fq0046nr. It blinks 5 long white 3 short white
Ive read all the comments but i still dont think i know what to do . So i take the bk off right ? Then what ? Oh im confused here someplz help me im not that tech savy
von
Antwort hinzufügen
Isuru Keshan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 80
Letzte 30 Tage: 335
Insgesamt: 82,247
