Zum Hauptinhalt wechseln
Repair guides and teardowns for Samsung feature phones. This category is for phones not using an Android or Windows operating system.
Replace broken charger port on Samsung Flight?
I have a Samsung Flight from AT&T (model SGH-A797). It will no longer charge b/c the charger won't fit tightly into the port. I know it's the port b/c I tried another charger & have the same problem. At first if I pressed in the charger hard enough & held it (or wedged it) at a certain angle it would charge a little bit. Now, it won't charge at all. I can't afford to have the port replaced ($70+ if Samsung does it). Is there any way I can fix it myself? I don't even need the phone charged if I can retrieve the info off the "brains" of the computer so I can re-enter it into my new phone. Any help would be greatly appreciated!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
you should be able to put a (borrowed) charged battery in and then sync/bluetooth/wifi with your computer to retrieve information or you could save contacts etc to SIM. I'd try your local phone repair shop and see how much he will do the job for..bet it's a whole lot less than $70! Take a look on ebay and see if you can find the port on it's own, take it to the local repair shop and he may just solder the new one on...or you could do it yourself??
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thx! I don't know why I didn't think of the charged battery thing myself. That's what I'm gonna do.
von
Antwort hinzufügen
Lucia Greenfield wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 6,075
