How much heat do I need to use losen the glue that holds the screen
Ist dies eine gute Frage?
I personally use a heating pad to conduct heat evenly with 75* C for about 8 to 10 mins based on the room temp and if you use 60*C let it sit for around 15 mins or more.
War diese Antwort hilfreich?
Eimantas Bruškis somewhere in the 50deg C to 70 deg C should work. You can use a heatgun or better yet a hot plate. If you use a heatgun make sure that keep it moving along the screen to distribute the heat evenly.
Personally, I use the manual air machine and prefer that the temperature to be used to remove the screen is 320, but it is necessary to distribute the heat over fifteen cycles quickly so that the edges of the phone are not damaged, and thank you
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 53
Insgesamt: 1,165
