Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
boot loop apple watch series 0 sport. on both charger & off
I have a issue on a series 0 sport which is basically a series 1. I did a battery replacement from a totally dead battery. The new one gets past the snake charge screen so the battery got initialized but now it boot loops. logo 3 seconds power off. repeat every 5 min or so. force reset doesn't fix it. do you think battery isn't good? not enough voltage? no damage to the gasket touch sensor that I can see. left it on charger for 3 days so far to no help. I unplugged the battery for a day to ensure it had no power and it didn’t help. I get the boot loop on and off the charger so the battery has some power at least. It never charged more than 2.2w according to my kill a watt meter and it did this in a weird way. 7 seconds charge 5 seconds no charge. it now shows 1.3w now with same same cycling. could this new battery be bad? never seen this before.
Update (03/20/2022)
Here is what it does one charger or off the charger. Reset doesn't help but does attempt to reboot fast than the 5min cycle
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You really want to have a look at those two other questions with the same issue:
Apple watch stuck in a boot loop
Apple watch original boot looping on the charger
Both point to the battery as being the likely issue. The latter link points to the battery replacement guide.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
stressmaster wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 555
