Zum Hauptinhalt wechseln
The Samsung Galaxy Core Prime Duos Android phone is a variant of the Samsung Galaxy Core Prime line. Model number SM-G360H/DS (SM-G360H/Dual-Sim). Released in November 2014.
How to repair ghost touch
the phone screen touches by its self
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare
This phone is not for working on touch
von
@chiranjitdas
See the suggestions shown below in the Most Helpful Answer
von
My mobile phone screen is damage and he doesn't work and keys can't work
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
So there’s actually a few things that can be causing this issue with your device.
  • The primary suspect could be an issue with the phone’s software. Make sure that the device is up to date. If anything else a forced reset of the device can help the issue.
  • The second suspect issue could be overheating or extreme cold. Definitely see if the issue continues if the phone is in a neutral environment.
  • If your phone is using a screen protector, definitely try removing the protector and see if the issue continues.
If all else fails, then it may be a defect in the screen that could be causing the issue. This would mean that the a replacement screen would be needed.
War diese Antwort hilfreich?
Bewertung 1
Makee sure monkey testing suit is turned off
Bewertung 0
Antwort hinzufügen
Tonny Mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 933
