Nikon D50 built-in flash does not work
The flash does not work. The flash will pop up when shutter button is pressed, however the flash does not fire.
Fix?
Ist dies eine gute Frage?
Fix?
Stan Keenum, of course your ISO setting is around 400. the flash will not work if your ISO setting is high. I would think that if nothing has happened to your camera and this just came up, that the first thing I check for would be the main condenser and the wiring to the DC-DC board. Also check the popup switch. You can download the service manual for your camera from here
War diese Antwort hilfreich?
I have a bad flash on my D50, can you please share the service manual again for it? Thanks.
You can Try it now
Thank You!
Bill, try it now
Hi, i cant access the manual, could u please share again
Many Thanks
Matt
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,582
