Zum Hauptinhalt wechseln
Repair and troubleshooting guides for the Rug Doctor Wide Track carpet extractor with model number 95371. This carpet cleaner was first made in 2016.
My machine will not stop spraying even though push button is released.
My machine will not stop spraying even though the push button is released. It will also not spray when using the upholstery tool. I've looked through the wiring diagrams and can only quess that it maybe the rocker switch. Do you have any knowledge on this?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Did someone just do some electrical work on the unit? I bought a rental at home depot and determined they had wired the floor/upholstery switch backwards. Problem solved but it took a couple hours to diagnose and correct. Dr J
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The wiring on the rocker switch has the long black and long white wire flip flopped. Pump stays on all the time in TOOL mode and you have the Carpet mode wired incorrectly.
War diese Antwort hilfreich?
Bewertung 1
The red button on Handle is faulty or stuck down.
Bewertung 0
Antwort hinzufügen
Randy ONeil wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 1,390
