Zum Hauptinhalt wechseln
The RipStik Ripster is a smaller and lighter version of the original RipStik.
The wheels keep falling off - how to repair?
The axle holding the front wheel to the trucks came out (the bolt that inserts into another bolt apparently unscrewed itself, and the wheel & spacers etc fell out). However, the parts we collected from the road don't appear to make sense together - does anyone have pictures or video showing how to remove and replace the wheels?
Specifically, I need to know what size spacers to order, order of construction, do you need to add LockTite to the bolt, or any other tricks.
I put them back together as well as I could but it didn't look completely right - the wheel was slightly offset to one side (the spaces/washers on either side of the wheel are different lengths!) 2 weeks later the wheel fell off again!
Thanks,
-- Demis
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
can you post a picture of what you have?
von
Einen Kommentar hinzufügen
1 Antwort
please see attached links.
one is replacement parts for the ripstick
https://www.ereplacementparts.com/razor-...
and this is a video of the wheel replacement. i hope this helps
https://www.youtube.com/watch?v=UrWy-eli...
EDIT: the wheels probably fell back off because from the pictures on the replacement parts site has loctite blue on the bolt itself to keep it from backing out.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Demis John wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 223
