Zum Hauptinhalt wechseln
Das größte und teuerste Smartphone, das Apple am 20. September 2019 angekündigt hat, verfügt über ein 6,5" OLED-Display, ein Kamerasystem mit drei Linsen und eine deutlich verbesserte Akkulaufzeit. Es ist der Nachfolger des iPhone XS Max.
20 Fragen Alle anzeigen
Do I replace the cunductive foil adhesive under qi charger?
I am replacing the rear housing on my iPhone 11 pro max and when peeling the wireless charger up there was a thin metal adhesive under it that I could not peel up without destroying. The housing I bought as a replacement does not have this adhesive on it so my question is do I need to find something to replace it because it looks like some sort of grounding material and if I do need to where can I find something that will be suitable to use. Thanks for anyone who answers.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Not really necessary. Alot of back glass replacements don't change this with no issues.
War diese Antwort hilfreich?
Bewertung 0
If you don't ever use wireless charging, then it's not required.
If you do, these adhesive layers serve to concentrate the inductive power transfer, making it more efficient, also it shields the rest of the phone away from induction to reduce the likelihood of interference.
Bewertung 0
1 Kommentar:
Ok that's what I figured it wasn't necessary but might serve to concentrate the induction or something of the sort. Thanks for the help time to twist a ton of tiny screws back into it and be done with it.
von
Antwort hinzufügen
Mick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 431
