Zum Hauptinhalt wechseln
The Sanyo VPC-X1200 is a 12.1 MP point-and-shoot style digital camera.
7 Fragen Alle anzeigen
Camera comes on and says card is protected on display screen
Display says card is protected and can not take pics. How do I fix the card, so i can take pics and keep the SD card in the camera.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
the insert card shows card protected
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
On the side of a SD card there is little groove/notch with a small plastic slider in it. That slider needs to be in the closest position it can be in the direction of the reader pins. Here is a video sowing you how to unlock the SD card. Here is a video showing you how to fix this problem if the little slider is broke or missing.
War diese Antwort hilfreich?
Bewertung 17
12 Kommentare:
Thank you so much. Instantly fixed my problem. : )
von
And thank you from me too :-)
von
Thank You !!!! I had no idea that was there..
von
Thank you , thank you , thank you :-)
von
valerie would like to thank you from the bottom of her heart. mijasval
von
7 weitere Kommentare anzeigen
But there are also instances where the slide switch will not correct the problem. One example is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Bewertung 3
My vpc S885 Sanyo.....turns on....screen says CARD ERROR do I need a new card
Bewertung 0
I purchased a new card the same make and size recommended in the camera manual Sandisc SDHC 16GB. checked that the lock was off and still got the message protected card when switching the camera on.
With no card in all the camera functions work correctly
Camera Finepix S8200. The card works in everything else.
Any ideas please?
Bewertung 0
some times you can make sure the switch is closes to the brass pins and put a piece of scotch tape over the switch and the little cutout on the opposite side. make sure not to cover the shiny pins. this has worked on some cases. the card readers and adapters are not advanced enough for a SDHC card and newer windows operating systems won`t work on some of the newer cards because it do not support encryption.
Hope someone finds this helpful.
Happy New Year People
Bewertung 0
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 36
Letzte 30 Tage: 166
Insgesamt: 36,373
