Zum Hauptinhalt wechseln
Repair guides for the circular saws made by Craftsman.
How do I test the switch
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi,
What is the model number of the saw?
von
I also have a Craftsman circular saw, model #6365. It does not work so I imagine that the switch is the problem. Any ideas on how to troubleshoot?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
To test the switch, you need to access it. You'll have to open up the casing to access the trigger switch in the handle. Once you can access it, check for continuity across the switch. Then, with your proves still in place, pull the trigger and activate the switch. If it reads OL then the switch is bad.
War diese Antwort hilfreich?
Bewertung 1
Hi @bigbob61660,
Go to searspartsdirect.com and search for Craftsman 6365 to hopefully find the parts diagrams and user manual.
If there, this will help to dis-assemble and test the switch etc.
Disconnect the power to the saw and use an Ohmmeter to test for continuity from the saw's power cord plug through the switch - both wires.
Bewertung 1
Antwort hinzufügen
William Speraw wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 613
