wifi and bluetooth not working
my wifi and bluetooth don't work after replace the battery
Ist dies eine gute Frage?
I would reseat the I/O data cable which connects the I/O board (with the Airport board) to your main logic board often I find the cable connection is the issue, you may need to replace the cable MacBook Pro (13 Zoll, Anfang 2013, Retina Display) I/O Board Datenkabel austauschen if the Airport board is properly seated and the antenna cables are in good shape.
War diese Antwort hilfreich?
First thing I would check is to make sure that the antennas are plugged in properly. The order of the antenna cables is kind of weird (to me anyways). Step 10 of this guide tells you which one goes where.
MacBook Pro (13 Zoll, Anfang 2013, Retina Display) AirPort Karte austauschen
I would also make sure the cables between the I/O board and the logic board are seated properly, since that's what carries the signals for bluetooth and wifi over.
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 10
Insgesamt: 106
