Zum Hauptinhalt wechseln
The ASUS TUF Gaming FX505 is a 15.6″ Full HD gaming laptop equipped with high-refresh-rate IPS panels and powered by up to 6-core Intel Core i7 CPUs and NVIDIA GeForce GTX/RTX-series mobile GPUs. It also features military-grade durability, dual-slot upgradeability, and a budget-friendly design aimed at gamers who want strong performance without premium pricing.
Why is my laptop's fan is very loud?
We all know that asus tuf has three category of performance silent, balance and turbo. So, last time usually when i set my laptop in balance mode the fan is not so loud and noisy but this day it become more loud and noisy. I have try clean the fan but it still not working..pls help
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
What is your CPU fan temperature at?
von
Try limiting cpu clock speed in bios, or maybe going into windows power management
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Try installing Park control and see what power profile the computer uses while in balanced mode. It usually uses High performance, try change the profile to Balanced or AMD Balanced and see if that might lower the fan speed ergo the noise.
War diese Antwort hilfreich?
Bewertung 2
Hello,
I had the same problem(fx705dt model). Firstly I thought I will have to replace the fans because I owned it about 3-4 years. I did and for some period of time it worked. About 2 days ago, it started again and I searched on youtube etc. I saw someone saying that if you change gradually from Silent mode to Performance and Turbo it will fix the case (this specific person told that he did that for a period of time and now his fans are fixxed, tbh it's something you can do for now, but I am warning you that my fans were replaced and still had the same problem, so I am gonna try this solution.)
Bewertung 1
Hi,
I think your laptops fans speed is very fast thats why it sounds loud.
I have found an article how to change laptops fan speed, I hope it will help you.
Thanks.
Bewertung 0
Antwort hinzufügen
Musyrif Muaaz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 66
Insgesamt: 14,254
