Zum Hauptinhalt wechseln
Reparatur- und Demontageanleitungen für die Logitech MX Master 2S Drahtlosmaus. Markteintritt 2017, zu identifizieren anhand der Modellnummern M-R0066, 910-005138, 910-005137 oder 910-005131.
11 Fragen Alle anzeigen
Sensor no longer picking up movement.
All other functions of the mouse work normally, it just will not pick up movement.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 15
1 Kommentar
Ok this is weird - the same thing happened to me too, on the SAME DAY!!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This happened to me last week on the same day as you posted your question, spooky!
To fix it I found this repair guide, which suggests that the gesture button can get stuck if it gets pressed... wrong.
I used this teardown guide to open the mouse up with an iOpener to soften the sticker adhesive and a metal spudger to peel it up, then broad tweezers to prevent tearing or grease from my fingers, I followed Steps 1-2. Then the first part of Step 3 to remove the black screws. I tested the button and its mechanism. Both seems to actuate fine, so I reattached it without tightening fully to give it a little wiggle room.
Once I reassembled the mouse and used the iOpener to soften the adhesive and smooth it back down the the metal spudger, it worked as good as new, if a little more crinkly on the bottom, which is undetectable in normal operation.
War diese Antwort hilfreich?
Bewertung 16
9 Kommentare:
I had the same problem, following these steps I solved it. Thank you!
von
works like charm
von
It helped me a lot! I just untightened the screws of gesture button twice, in first time it was also helpful, but after one hour the problem started again, after the second untightening is it good. Thank you a lot! My wife has a gold standard "new" mouse after that fix :)
von
Perfect, thank you so much... Even our shop told me my mouse was dead... And need to be changed.
With you tips, my mouse is now working as usual !!!
Thanks
von
Jest letting people know that this solves the same issue for the original MX Master!
von
4 weitere Kommentare anzeigen
Well my friend this video might helpful for you.
https://www.youtube.com/watch?v=VbgN4Ywt...
Bewertung 0
Antwort hinzufügen
Brentleigh Ward wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 102
Letzte 30 Tage: 332
Insgesamt: 11,546
