Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
It's very likely that the speaker has been damaged. Such as a physical crack on the membrane. As it vibrates when it plays, the pieces crash against each other and that's the cracking sound you hear. You most likely need to replace it. It shouldn't be too expensive.
von Funk Addict
