Why wont my phone recives any signal?
After a hard fall my iphone on sparadicly recives any sort of signal, 3g or network. What would be the most likly cause of this?
Ist dies eine gute Frage?
Two main reasons this has happened
- Loost antenna connection due to impact force
- Damaged logic board
If the antenna has become loose, all you will need to do is remove the back cover and re-seat. If the logic board has been damaged then you will need to take your phone to apple and request for a replacement.
War diese Antwort hilfreich?
usually a loose antenna
you can change your sim card and try it .if that your cellphone doesnt work ,maybe it was broken.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 779
2 Kommentare
Seeber, can you tell us which iPhone you have?
von Phillip Takahashi
i have the iPhone 4 first gen.
von seeber
