Zum Hauptinhalt wechseln
The Honda Element was a compact crossover SUV based on a modified CR-V platform, manufactured in East Liberty, Ohio and offered in front-wheel and all-wheel drive formats
6 Fragen Alle anzeigen
Rear of vehicle is squeaky, help!
My 2007 Honda Element is very squeaky. It appears that the noise is coming from the rear wheels of the vehicle and happens when the car is turning and sometimes just driving down the road. I have taken it to my mechanic, and they looked it over. They said there is nothing wrong with it besides it needing to be lubed up. They said my brakes, bushings, etc. are all fine. They lubed it up and it is only slightly better. They told me that I will have to get them to do it every few months until it is saturated. They did not charge me for anything, which is good. There has to be something that none of us are seeing. Please help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @retrogamernc ,
Just to eliminate the possibility. Check if the rear shock absorbers are OK.
At the rear of the car go to one corner of the car and push down hard and as far as you can on the body of the car and then release. Do this two or three times in a row, to set up a bouncing/rocking motion. When you stop, the car should bounce up, then settle back to the at-rest height. If the car bounces more than twice, you most likely need new shocks. Do this on both sides.
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
John Toomey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 1,222
