Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
kristjan666 first you want to check your charger. Make sure that it works. then check your cable and see if that is working properly. After that you are looking at replacing the batteries and repairing the charger port. I suggest you check videos like this to at least get you into the speaker.
von oldturkey03
