pulleys do not move the belt and a high squeal occurs?
What do you do if the belt is properly routed but when put in forward the pulleys do not move the belt and a high squeal occurs?
Ist dies eine gute Frage?
Likely a bad spindle bearing that is seizing up. Check by hand if any spindles feel locked or hard to turn. If so replace both the top and bottom spindle shaft bearings. Examine the shaft. If it looks bent replace the shaft also or the whole spindle assembly. Leave the spindle on the deck and just remove the shaft as the hold down bolts are very brittle and prone to breaking.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 77
