Zum Hauptinhalt wechseln
iStat Pro Report - Rear Main Fan 0 rpm
iBook bottom has always been extra hot. Recently replaced battery and DC in board. Runs great, but needs a thermal blanket. Should I replace the fan, or is more troubleshooting needed first.
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Found an excellent app - G4FanControl 0.6.1. Resets threshold settings. iStat now shows 8200rpm. Much cooler too.
von
Hi- good job solving it yourself, can you please though put this comment as an Answer instead and them Accept it so we can see what worked? Thanks.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
OP answers own question
Good job and thanks for coming back to share solution.
Found an excellent app - G4FanControl 0.6.1. Resets threshold settings. iStat now shows 8200rpm. Much cooler too. carlstaff, Feb 1 @ 10:42 PM
This answer needs to be accepted or voted up.
N.
War diese Antwort hilfreich?
Bewertung 1
Do you hear the fan when you watch videos on youtube or when you do intensives jobs ? If no then replace the fan. Cheap repair.
Bewertung 0
1 Kommentar:
AKA- Flash
von
Most likely that istat is just not compatible with your iBook..
Their website advises that it doesn't work with most PPC Machines..
Bewertung 0
1 Kommentar:
I highly doubt that it's a false positive.
von
Antwort hinzufügen
carlstaff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,628
