Zum Hauptinhalt wechseln
Veröffentlicht am 24. Oktober 2011 / 2,2, 2,4, oder 2,5 GHz Quad-Core Intel Core i7 Prozessor
394 Fragen Alle anzeigen
Mac boots to white screen, nothing else works.
I have a Late 2011 MBP that just boots to a blank white screen. I've tried the usual SMC and NVRAM reset, and the problem still persists. It also cannot boot into target disk mode, nor recovery mode.
I don't know if it's the GPU or something else, I'm completely lost.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
You'll first need to do a full SMC reset. Pop off the bottom cover and disconnect the battery, now with nothing connected press and hold the power button for a good 15 secs. they lets the logic board charge to be discharged. Now plug the battery back in and the MagSafe. This time when you start the system press the T key to enter into Target Disk Mode. Do you see the FireWire/Thunderbolt icons on the screen? If you do they you proved the discreet GPU has failed and SMC was stuck in a latched state which is why you couldn't get past the reset.
von
I don't see the FireWire icon on the screen, it's still showing a blank white screen
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I found out the issue:
The SSD. Somehow the SSD I had in it was causing the issue somehow
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Average Old MBP User wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 40
