Zum Hauptinhalt wechseln
Die größere Ausführung von Samsungs zehntem Smartphone-Flaggschiff ist mit Android 9.0 (Pie) ausgestattet. (Erscheinungsdatum: Februar 2019).
Why is the bottom thrid half of my screen flickering white
the thrid bottom half of my phone flickers white and sometimes green and everytime I turn off my phone it won't turn back on unless I press the power button multiple times.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
yo i hav a s10+ too and i dropped and the screen got da same problem
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
@katelynnkatelyn sounds like you are having a broken screen. For now, disassemble the phone, check the display connector to make sure it is properly seated and shows no bend pins, corrosion etc. If that works out okay you will have top replace the display and re-evaluate.
Samsung Galaxy S10+ Display tauschen
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The bottom of my phone s10 is flickering constantly like 2/10 of my screen how do I fix the problem??I dropped it but its not cracked
von
@daevdshula teh glass may not have cracked but sounds like the matrix took a hit. Without seeing it and strictly going by your descriptions, a new display should fix this.
von
Go to developer mode through settings
Disable HW overlay
And that's it.
Basically it's firmware issue but sometimes this type of error/Flickering is caused by non suitable settings.
Try this bro
Bewertung 1
If u have the eye comfort shield setting on turn it off. This is what fixed it when I had the same problem
Bewertung 1
1 Kommentar:
Was totally amazed to find that unselecting the Eye Comfort Shield cured my issue. TY for suggesting.
von
Antwort hinzufügen
kate wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 90
Insgesamt: 7,506
