On/off switch jammed
Hello, my on/off switch is jammed and sound get distorted when I shake my head or when turning it on first time I needed to tweak switch a little to get proper sound. Is there any guide to disassembly guide?
Ist dies eine gute Frage?
4 Kommentare
Hi i have open the left side and i use contact spray in the switch
GAP and i used on 5-6 times (on/off) at the momend looks like to working
von Savvas Ioannidis
Cool, glad you got it fixed! Congratulations.
von Juan Garcia
Which screws did you need to take out in order to get inside? I've taken out two screws underneath the foam pad, but not the other four as they look like they are holding the speaker. Do you need to also remove the two allen screws behind the panel?
von Michael Wolfe
You need to remove a total of six small Philips screws. The speaker-panel of the headset then just lifts out, no clips or tricks. Four do anchor the speaker itself, but they also hold the front and back together.
von Forge
