Replacement battery for HX9120
I'm looking to replace the battery in my Sonicare FlexCare HX9120.
Do you have a replacement battery for this model?
Thank you for your time,
Richard
Ist dies eine gute Frage?
Richard
Yes and a guide on how to do it, look here
War diese Antwort hilfreich?
rmwrench here is the link for the battery Sonicare Flexcare / Flexcare+ / Healthy White / DiamondClean Battery
This is the equivalent to the sony:
https://toothbrushbattery.com/guides/phi... I'm not able to say which of the batteries on iFixit are correct if that one isn't. I have no involvement with iFixit business function but I expect an answer will be along shortly.
Are you certain of your information? I've now found 3 references that say seemingly this IS the correct replacement. I've alsorefferredd your comment to iFixit.
What I did to find several candidates was search for sony 4235 010 32899 substitute, the video I posted in my answer state if the pins are offset to insert at an angle. I can't check that for veracity, unfortunately, but you can search for other substitute cells.
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 33
Insgesamt: 1,009
5 Kommentare
I found out this battery won't fit my HX9120 Phillips Sonicare, it requires a Sony P/N 4235 010 32899. Unfortunately, I haven't been able to locate this battery anywhere.
von rmwrench
rmwrench have you determined what the differences are? Size, contact location ? Is this the model where the battery contacts are offset or are they coming from the center?
von oldturkey03
Hi oldturkey03 I don't know the size of the battery I need; all I know is it's longer and smaller in diameter then the one suggested that would work which it doesn't, this is the Item code: IF389-000-2 of the battery that won't fit/work. The part number off the battery in my unit is all I have to go on and up to this date I haven't been able to find a replacement battery any where.
von rmwrench
As far as I can tell the battery contacts are off set.
von rmwrench
I am going through this now as well. As far as I can tell, it doesn't look offset. If I get another battery, I just want to make sure it fits. It looks like an AA battery. The lead maybe too wide so it not fit into the hole. I am thinking I could take off the old leads from the bad battery and use it on the new battery. Solder it in so to speak. It is weird that you cannot find a Sony replacement battery for this one.
von Buckeroo
