How to resolve flickering issue in my phone
Screen turns full black
Ist dies eine gute Frage?
Dinesh Rawat since it did have some water exposure (no matter how slight it might have been) you do need to try and resolve that. For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse as this may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using something like this video You must remove all EMI shields from your circuit board. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, Replace the battery and reassemble your phone and reevaluate. It is possible that you only have a damaged display but it is also possible that you are having shortened components on the board. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 728
5 Kommentare
Dinesh Rawat. It turns black or it flickers? Anything happened to the phone before? Did this just start? Any updates done on it? What have you checked? This should be a relatively new phone. Still covered under warranty?
von oldturkey03
Slightly expose to water and this thing started from last 2 days ,during operation ful screen become black
von Dinesh Rawat
It is under warranty but manufacturers refuses to repair it.
von Dinesh Rawat
Dinesh Rawat "manufacturers refuses to repair it." because of the water damage I suppose.
von oldturkey03
Now what should I do to resolve this?
von Dinesh Rawat
