Zum Hauptinhalt wechseln
Controller für das Valve Index VR-Headset wurden am 28. Juni 2019 veröffentlicht.
Thumbstick drifting in neutral position of it
Left hand thumbstick is in neutral position but game character moves on.
You have to push and pull the thumbstick in different directions to stop the drifting.
How to fix that?
Ist dies eine gute Frage?
Bewertung 10
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
For those looking for a solution.
Look on reddit guide:
https://www.reddit.com/r/ValveIndex/comm...
This is the replacement part:
FJ06K-S Switch
War diese Antwort hilfreich?
Bewertung 1
Hello!
Sadly i don't know how is this controller really build, but i guess it's the same problem like in xbox controller. Analog inside just got broken. If you still have guarantee just send it back. If not, you need to replace it with new one. It's called 'FJ06K-S' probably. If you have soldering iron and some skills in soldering go ahead.
Good luck
Bewertung 0
Ive dug around a lot in my index controllers because of drift and the capacitive sensor on top, as far as I can tell there aren't any official replacements online, but the joysticks just use 2 through hole potentiometers so for drift, contact cleaner might work. You can probably follow the instructions on replacing the strap to get the top open, but if you are under warranty, because of the limited part availability I would just get it replaced until they stop giving you replacements.
Bewertung 0
Antwort hinzufügen
Tom Hans wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 38
Letzte 30 Tage: 189
Insgesamt: 14,280
