Zum Hauptinhalt wechseln
Die größere Ausführung von Samsungs zehntem Smartphone-Flaggschiff ist mit Android 9.0 (Pie) ausgestattet. (Erscheinungsdatum: Februar 2019).
Replacement Screen kit compatibility
Hi, I would like to know if the replacement screen on the iFixit kit compatible with Samsung Galaxy S10+ Interntional models?, i was told at an Authorized service center here in Canada that there are compatibility issues with replacement screens of Canadian models and International models. I would greatly appreciate any help.
Thank you!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I am currently experiencing the same issue on my Samsung S10+ SM-G975U
I bought a replacement screen.
But seems it's not compatible.
It works sometimes after a while it freezes and won't respond until you lock it and unlock it sometimes I've to perform this task several times for it to be responsive again.
Once it works, works normal no problem until after a few minutes and starts acting the same way.
If there's any solution without changing the screen please help.
It's annoying 😒
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Jeff Carreon I have not seen or heard that one but you do want to make sure that you order based on your model. For the S10+ the versions are SM-G975F/DS (Global); SM-G975U (USA); SM-G975W (Canada). I suggest that you contact iFixit Support by any of these means and see what they can tell you. On here we are mostly volunteers that are not directly involved with iFixit sales.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jeff Carreon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 462
