Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
338 Fragen Alle anzeigen
No power chime/no power/no fan/no noise when button press
When I try and turn on my mid 2010 iMac 21.5 inch, nothing happens. When I plug it in, the first diagnostic green LED turns on, and when you press the power button it immediately turns off and nothing happens. Literally nothing. Nothing at all. No chime, no other lights, no fan spin, no hard drive spin, nothing. I have ordered a completely new replacement board and put everything back together. The same problem happens. Could this be the power supply? I ordered one off of eBay and it should arrive on friday, the 10th. What else could this be as I've eliminated the possibility of it being the logic board as I replaced it already.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It could be your power supply, but it could be the power button, check both.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
It could also be your RAM
von
Antwort hinzufügen
Joshua Glenn White wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 20
