Zum Hauptinhalt wechseln
Die Tastatur für den 2-in-1 Laptop von Microsoft, das im Oktober 2015 auf den Markt kam. Intel Core i5 oder i7 der 6. Generation.
35 Fragen Alle anzeigen
screens terminals has small signs of corrosion , so gpu not found.
My partner has been disinfecting my surface book 2 during covid and started to show signs of small amount of corrosion in the screens port that connects the base/keyboard that also has to GPU in it as the nvidia GPU showing up and continuous connect/disconnect screen tone.
How can i repair or clean the port?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Chris Cameron that is usually caused by corrosive materials destroying the nickel and thus losing conductivity. You could try and use some isopropyl alcohol and cotton swab to clean it. Then you will need something slight abrasive to remove the pitting of it. Try a thin stiff brush or a hard (smoking)pipe brush. Something like this always comes in handy.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Chris Cameron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 64
