How do I fix my roomba
I did some research and my Roomba has a error 1 I have tried calling vacuum repair shops and found nothing.
Ist dies eine gute Frage?
error 1 on those Roombas means that the main brushes are stalled.
try cleaning the brushes of hair and other crud, be sure to focus on the ends of the brushes.
hope this helps
War diese Antwort hilfreich?
I'm getting an error 1 and have completely taken apart the wheels, brushes, etc. and removed all the hair I could find. Still nothing. :-(
Error one (1) means your robot is on an obstacle or an uneven surface and a side wheel is stuck. If this is the case, lift your robot off the floor, place it in the center of the room, and restart the clean cycle. If this error occurred on a flat surface, check the wheels for obstructions.
Note: Use a Virtual Wall® to keep Roomba® away from problem areas.
900 and 800
700, 600 and 500
Please visit the iRobot Store - Parts and Accessories or use an authorized retailer to order a part. If you believe you're in warranty, please contact iRobot Customer Care.
For expedited service, please have the following ready:
It is worth noting that the error codes for the Roomba 4000/400 series are different than the codes for the 500 series and up. I am guessing gunk got into the brush gearbox causing the Roomba to detect that the brush motor is drawing too much current. If not that a motherboard issue could be present =\.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 88
What symptoms does your Roomba display? Usually the error one (1) means that the battery is not detected. Does your Roomba charge?
von oldturkey03
