Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
102 Fragen Alle anzeigen
Can I replace dark gray display with a silver display?
My dark gray display is damaged. The store doesn’t have the dark gray display in stock but it has the silver display. Is the silver display compatible with the dark gray MacBook Air? I don’t care about the matching optics. Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi
YES they can do just that
There are no differences apart in the electronics the only difference is the colour:-)
In my opinion I would wait but if you are ready to go ahead I say go for it as it would be unique
If you want it to look normal I would get a nice skin for it
Hopefully this answers your question
War diese Antwort hilfreich?
Bewertung 2
If they are the same model, then yes, they would be compatible, regardless of color. Apple would not allow you to do this sort of swap, but the parts are functionally the same so it should still work as a replacement screen regardless. So if the aesthetics don't matter to you, then this shouldn't be an issue.
Bewertung 2
3 Kommentare:
@flannelist great answer as always. Hopefully you are considering to expand on the About page on your profile. That way we all get to learn a little bit about who we all are and what we stand for. Makes it easier to interact and creates a much stronger community :-)
No pressure of course. It's totally up to you.
von
@oldturkey03 It's on the agenda :) I've been meaning to do it for ages, but alas. ADHD and an ever changing landscape at work means it keeps getting deprioritized. Maybe that will be my task for the bus ride home tonight.
von
@flannelist I totally get that:-) Looking forward to seeing it when it’s up. Bus ride home. How awesome is that! Stay safe
von
Antwort hinzufügen
Kevin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 56
