Zum Hauptinhalt wechseln
Reparatur- und Demontageanleitungen für Uniden-Telefone.
UNIDEN DECT 1735 does not record any incoming messages
dect1735 It does not pick up any messages
Update (06/22/2022)
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare
The manual is not helpful.
von
where to get a manual I did not get one
von
@margaretpennisi
What is the model number of your phone?
The model number is usually located on the bottom of the base station or can be under the battery in the phone.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
Is the answering machine turned on?
Does the answering machine answer an incoming call if you don't use the handset to answer the call i.e. can you hear the machine's pre recorded answer message when calling your phone number from another phone?
Here's the user guide for the phone. Go to p.20 to see how to set up the answer machine service in the phone.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
von
@holly2023
Not all Uniden models share the same menu setting options
von
The model number is: DECT 6.0 DECT1735+2 28002612
von
@holly2023
What problems are you having in setting up the answering system, as the manual seems to explain it reasonably well?
von
The manual is quite clear, however the machine does not always do what it has been set up to do. The manual is also missing a few little bits of description.
von
I bought a 1735 refurb that would not record messages on the answering machine. The handsets came already registered when the item was received. By deregistering all of the handsets, then reregistering them I got it to record messages. See the manual for instructions.
Bewertung 1
Antwort hinzufügen
bbgrandma2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 38
Insgesamt: 1,981
