Zum Hauptinhalt wechseln
A2116 / 2019 / 3,6 GHz Quad-Core i3, 3,0 GHz 6-Core i5 oder 3,2 GHz 6-Core i7 Prozessor. Veröffentlicht am 19. März 2019.
Can I replace the Fusion Hard drive with an SSD on a 2019 iMac? and...
Will it cause any issues with the way the existing Fusion flash blade recognises or communicates with the new SSD?
Is it necessary I buy and connect a Thermal Sensor?
Can I buy any SSD? or are there some which cause conflicts?
I appreciate any help.
Thank you
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
The blade SSD is used as a cache drive to the 2.5" HDD when the two are setup as a Fusion Drive set.
When you remove the HDD replacing it with a SSD you will sever the Fusion Drive so the Blade SSD will just sit unused. The first versions of Fusion Drive used a 1TB HDD and had a 32 GB SSD for the cache drive, after August 4 it had a 256 GB SSD.
If you have the larger blade SSD I would recommend reformatting making it the OS boot drive as the PCIe/NVMe interface is faster than the SATA III (6.0 Gb/s). Sadly the small 32 GB drive is not large enough to do much of anything.
Here's the guide you'll need to follow to replace the HDD: iMac Intel 21.5" Retina 4K Display 2019 Festplatte tauschen
If you can I would upgrade the blade SSD to something larger 256 is a good size for writing and simple web use with the macOS on it. Going with 512 or larger offers a lot performance! Here's the guide for it iMac Intel 21,5" Retina 4K Display (2017) Blade SSD austauschen
Otherwise don't worry about the blade SSD, just let it sit unused if you go with the 2.5" SSD.
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 Festplatte Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
James Rice wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 449
