Zum Hauptinhalt wechseln
Ultra-Thin Laptop Processor: Intel Celeron N4120 @1.1GHz 1101MHz Turbo Boost: @2.6GHz GPU: Intel UHD Graphics 600 8GB RAM DDR4 256GB SSD TPM 2.0 (Supports Windows 11) Has fingerprint reader. No optical drive. 720p HD camera. Kensington Lock 2x USB Type-A 3.2 Gen 1 (5 Gbps) 1x USB Type-C Bluetooth 5.1 3.5mm Combo Jack Full HD IPS panel 1080p 60hz display Comes preinstalled with EFI Shell. (Windows is easy to install)
3 Fragen Alle anzeigen
Unable to access BIOS after dual booting Pop!_OS and Windows 11 Pro
About a few weeks ago, I decided to dual boot for the first time. And, Pop!_OS appeared to be the perfect linux distro.
But, one small issue (actually not that small...), my BIOS doesn't quite work anymore!
When I press f2, the screen just blacks out, and my mouse just reverts to its basic lighting option.
I have uninstalled Pop!_OS, yet, my BIOS still has the same issue...
I have the acer BIOS version 1.05, the latest version for this laptop.
I have tried installing the update file to the same version, but it detects the current BIOS I have and quits.
To anyone with a laptop very similar, like the SF114-34, or even mine, please help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Disconnect the main battery (lower half in video)
https://www.youtube.com/watch?v=AmTCoLq7...
for SF114-32
https://www.youtube.com/watch?v=cwy23nmX...
for SF114-34
and disconnect the CMOS battery (the coin battery is covered in black plastic with a black and red wire coming from it. Follow the wire along until until you get to the white plastic connector. Slowly and gently pry this off. 32 it is on top left and 34 model it is lower right.
Press power button for 30 seconds to discharge any residual charge. Reconnect everything and power up.
Did that work?
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Ok, no way I'm doing that...
When i unplugged the battery, it just started to do these tiny, quiet beeps like it's crying!
Terrifying!
von
Also, that did absolutely nothing, i asked the Acer community and they told me that I can reinstall windows, maybe I'll backup my stuff and try that... Thanks for trying to help though!
von
@alexsucks This was with the power supply/charger unplugged?
von
ohhhh. i unpluged the wrong battery, where is the cmos battery anyways?
von
Antwort hinzufügen
Alex Sucks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 435
