Zum Hauptinhalt wechseln
The Sony TCM-919 is a portable and lightweight cassette player with audio recording capabilities. This device of the 1990's is equipped with a 3-digit tape counter, microphone, and auto-shut off, and a front speaker system.
My TCM-919 player is not spinning
I put on the batteries already but when I press play or record nothing is moving but it make noises but no music from the tape and I can see the tape is not moving
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is only one way: use this guide and open the device. Switch it on. Have a look to the gears, perhaps you can see a broken rubber belt?
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
How can I know if the rubber is broken or not?
von
@iitoobb Step 5 picture 3 of the above guide shows the rubber belt from the motor to the spindle. That is the belt that will have to be present.
von
Thanks , I’ll try to find a new rubber belt because mine looks more loose
von
Antwort hinzufügen
Iitoobb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 21
Letzte 30 Tage: 28
Insgesamt: 290
