Hi
Here’s some answers for you:-)
The difference between the 2010 and the 2012 is the cpu that comes pre installed but apart from that there is no difference (I wouldn’t let that be a decider as once you have upgraded them there is no difference at all
The difference between 4,1 and 5,1 is they use different CPU types
4,1 needs de-lidded Cpus
whereas
5,1 need ones that have a lid/heats spreader
As far as I know you can’t use a 4,1 cpu tray in a 5,1
One more thing to add if you get a 5,1 you will want to flash the firmware to5,1 so you can use better cpus
If you need any help doing this leave me a comment and il try my best to help:-)
Hopefully this answers your questions but if it doesn’t just ask me:-)
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
