Zum Hauptinhalt wechseln
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
Device not charging after 1%
I plug in my device using several chargers to test if it's the charger is the problem but it won't work. After I plug it in the battery sign show that it's charging and after it turns on at one percent its not charging when it's on and I can't stop it from turning on automatically
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
Please answer
von
sounds like u have to take the battery out and put it back it sometimes tablets do this do to their poor design
von
or could be the cord is malfunction that happens to do to another poor design
von
The battery cannot be removed
von
how does it work if there's no way to remove the battery that means there's no way to put it in either? your logic man
von
Einen Kommentar hinzufügen
1 Antwort
If it charges in the beginning and you do not move it then there is no reason to think that it is a bad cable or connector.
The most likely issue is a spent battery. See if you can find a battery test app and run that to see what the health of the battery is.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Ok thak you very much
von
how about a rating if it helped?
von
Antwort hinzufügen
Millie lee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 64
Insgesamt: 1,300
