Zum Hauptinhalt wechseln
Sony digital still camera model DSC-H50, February 2008, 3.0" tilting LCD, 9.1 MP CCD, Zoom 15x (31-465mm), f/2.7-4.5
Viewfinder not working, LCD is okay. How to repair?
My Sony DSC-H50's viewfinder does not illuminate when I switch from LCD to viewfinder mode. All other functions work, including the external LCD display. Does anyone know of a repair guide or video? My searches have turned up nothing.
EDIT: After posting this yesterday I did see the viewfinder flash (illuminate) briefly several times, but not in any reproducible way and not when I tried to switch to viewfinder mode. Seems most likely it is a loose connector.
EDIT2: I have attached the Sony repair manual (to the camera info page), but it doesn't really list steps, so I'm hesitant to dive in.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
Have you tried disconnecting any unnecessary modules and testing ? I have encountered a similar issue on some canon cameras when the flash module was shorted
von
Thanks, HIF. This camera has no accessories/modules attached.
von
@hypercaff hey, I think you misunderstood me. I’m taking about the built in flash module which is present in this model.
von
You're right, I did misunderstand you. The flash module works fine. I haven't disconnected it because I haven't yet figured the right way to disassemble the camera.
von
@hypercaff this service manual should help.
Good luck !
https://www.manualslib.com/manual/125436...
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I got the camera apart (Thank you, @how_its_fixed!) and found that the ribbon cable between the main board and the viewfinder has several broken traces as shown below. For perversity's sake, pics were taken with the camera itself.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
It appears that flex was laying against something that got hot. That looks like it is burned. Replacing the cable should work, just make sure it is not touching what caused that.
von
I have the same problem today with the EVR of my Sony alpha 58 DSLR. Thankfully, I was able to see your post. This gives me a lead to how I can fix my camera. But then, how do you call this ribbon?
von
@josemarievillas This type cable is called a "flex cable", and, in this case, I assume it would be called the "viewfinder flex cable," or something similar.
von
Hilfreichste Antwort
Most cameras have a button to switch between LCD and viewfinder. You didn't say that you tried that or that it is suppose to be both on.
Bewertung 1
1 Kommentar:
Thanks, Bill. This camera only allows use of either the viewfinder or the LCD, and when I switch to viewfinder the viewfinder remains dark.
von
Antwort hinzufügen
Hypercaff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 1,849
