Zum Hauptinhalt wechseln
Das Pixel der dritten Generation wurde von Google im Oktober 2018 veröffentlicht.
93 Fragen Alle anzeigen
Pixel 3 dead, what will fix it?
My Pixel 3 is completely dead. No light, no vibration, no reaction to any button presses. If I put it on a wireless charger, the charger recognizes it, but then stops charging immediately. If I plug it into a USB-C power meter, it recognizes it's connected but doesn't charge. If I connect it to a computer, it doesn't list it as a newly connected USB device.
I noticed the battery was bulging, so I replaced that with the ifixit replacement. It still is dead.
So I'm wondering what might account for these failures? A bad replacement battery? A bad charging port? A bad motherboard? A cabling issue?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
All the above, plus possible residue on PCBs from the bulged battery.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I think the most likely repair could be narrowed down from these symptoms.
Also, the battery bulged, it didn't leak, so why would there be residue?
von
On my dead Pixel 3, connecting a USB cable to my Windows PC shows an unknown device:
QUSB_BULK_CID:xxxx_SN:xxxxxxxx
Many people are reporting this problem.
See:
https://forum.xda-developers.com/t/fix-p...
However, there's no solution at this time.
Bewertung 0
1 Kommentar:
Mine does not show up as a device when connected to a PC via a USB cable. I thought I read somewhere about there being solutions if that were the case. Perhaps I misread.
von
Antwort hinzufügen
ross wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 7
Letzten 7 Tage: 23
Letzten 30 Tage: 88
Insgesamt: 495
