Zum Hauptinhalt wechseln
The second-generation (Mk 2) Ford Focus was launched in 2004 as a three- and five-door hatchback and an estate variant.
Ford Focus horn failure. Please Help!
I have a Ford Focus Estate, I got cut up at a junction and was unable to show my displeasure in the usual way as the horn stopped working. Any help would be great.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Fuse brown, solenoid failed. Check the manual for which number fuse it is and check it first. Also check the wires that go to the horn as they can corrode and break off.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Unfortunately it wasn't that simple, tried all of that and still no noise.
von
Faulty horn? Test it then if working maybe a faulty horn switch. Put a multimeter on the horn wires and have someone push the horn button. If all else fails then possibly a break in the wire somewhere.
von
Antwort hinzufügen
Gareth Tongue wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 35
Insgesamt: 545
