Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz), 2,5 GHz (Turbo Boost bis zu 3,7 GHz) oder 2,8 GHz (Turbo Boost bis zu 4,0 GHz) quad-core Intel Core i7 Prozessor mit 6 MB geteiltem L3 Cache.
30 Fragen Alle anzeigen
Are MacBook Pro bottom plates interchangeable across different models?
This might sound like a dumb question but I am replacing the bottom plate on my 2015 retina with a GPU and when I got my replacement backplate I noticed that it didn't have the cutouts on the bottom for the GPU. Will this be a problem or does it not matter?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Let me put it to you this way... Your car tires are quite worn almost with no tread, would you go on a long trip on them, how about a very short trip?
Sadly this is a similar issue, if you are a heavy graphics I would get the correct bottom cover.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Alright got it. What exactly is the black tape and what are the cutouts designed for?
von
@jimmysofat6864 They are heat isolators and the outside part is prevent dust build up.
von
Antwort hinzufügen
jimmysofat6864 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 68
