Zum Hauptinhalt wechseln
Der Nintendo Game Boy Advance kam 2001 auf den Markt. Für Reparaturen braucht man keine besonderen Werkzeuge und keine Wärme.
20 Fragen Alle anzeigen
Game Boy Advance starting up in black and white
I Bought a modded GBA, and it was working fine, but the screen was miss placed, so I opened it and put the screen on the right position. When I tested with the gba still open it was working fine, but after closing it, the screen now has no colors, everything else works just fine, it's only the screen that is now on black and white. I believe it's a IPS V3 screen. I tried re-opening, and checking for burned components, broken cables, but nothing.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Try reopening it if there are any ribbon cables make sure they’re in all the way
War diese Antwort hilfreich?
Bewertung 0
I had the same issue recently and learned how to fix it by luck. Hold your finger over the touch sensor that changes brightness and then hold either start or select, it may take a few seconds but the color will turn back on. It can also be done again to make it black and white again. Sometimes I have to try it a couple times too, but it always works for me. Hope this helps😸
Bewertung 0
1 Kommentar:
I have the same problem on my Gameboy color and I tried doing this but it didn’t change.
von
It sounds like your Game Boy Advance might be having a bit of a glitch. One thing you could try is checking the batteries or power source to make sure everything's connected properly. Sometimes that can cause weird issues like the screen going black and white.
If that doesn't do the trick, diving into some forums or tutorials online could be a good next step. I stumbled upon this helpful thread on https://guidedhacking.com/forums/gamephr... that might have some useful tips: GamePhreakers Game Modding Tutorials. They often have solid advice for fixing tech stuff like this.
I hope one of these suggestions helps you get your Game Boy back to full color soon!
Bewertung 0
Antwort hinzufügen
Marmita Fria wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 75
Insgesamt: 2,726
