Zum Hauptinhalt wechseln
Reparaturinformationen und Support für das Dell Precision 5520. Erschienen im Januar 2017.
Is it possible to run a Dell Precision 5520 without a primary battery?
The primary battery on my Precision 5520 laptop is not working or at least the BIOS diagnostics think it is not installed. It fails the functional test with error code 2000-0131. Can the laptop still be used without it?
At the moment it does not boot up Windows. I am wondering if I can change the BIOS configuration to ignore the battery?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I have tried on my own Precision, and I can confirm it will not work. When it recognizes it has no battery, it tries troubleshooting and then shuts down. I haven't found a way around this, but unless you need extra space for something, it should be fine as long as your power brick is ok. I just keep my battery installed, but never unplug my laptop from a power source, so it's basically a desktop. Either get a new battery if you want portability or keep the old battery in and use it as a desktop. Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
James Treacy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,244
