Zum Hauptinhalt wechseln
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
17 Fragen Alle anzeigen
Arched floor lamp - metal pole snapped
I'm looking for a way to fix this lamp (similar to the one shown here). My sister's cat decided to hang from it and the metal pole snapped just above the screw-in part that connects the pole pieces (also shown here).
I was thinking some kind of metal bracket that can be attached, tightened with screws and then painted brown. I'm just not sure if such piece exists. I'd be fine with any kind of cheap, safe way to do it without having to replace the whole thing. Any help would be greatly appreciated!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I assume this is where it broke as the other piece obviously screws into the base stem.
I can't tell from the pic what the remedy might be, but it might be that the nut was slipped over the shaft and the end was flared. Then the silver piece was screwed into the nut. So, now the flared end has slipped out.
I would remove the lamp so that you can disconnect the wire and remove it thru the bottom. Then totally disassemble that section to see if I am right. If so cut off the flare and redo it. You will probably need a flaring tool to do it right.
Otherwise, I would remove that flare and get a piece of oak or maple and drill a hole from either side, the right size to fit snugly on top and bottom. Make sure it is long enough and thick enough to supply requires support. You may need to configure a couple of set screws.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Bill, this is helpful. Thanks so much for your response!
von
Antwort hinzufügen
Jill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 12
Insgesamt: 189
