Why is My Netgear orbi flashesh white while powering on?
I am not getting internet from my router orbi. It is blinking white on ring led. Please suggest to me what to do.
Ist dies eine gute Frage?
Netgear Orbi flashes white while power on. This can be caused by a few things. The most common issue is a bad or failing router. The router may not be able to keep up with the demand of the Orbi network, and may cause the lights to flash white.
Another issue can be if there is a faulty Orbi satellite. The satellite may be unable to communicate with the router, and may cause the lights to flash white. In either case, addressing the issue is the best course of action. If the issue is with the router, there are a few options available.
First, you can try resetting the router. This will clear all of the router's settings and may resolve the issue. If that does not work, you can replace the router. If the issue is with the satellite, you will need to replace the satellite. You should know more about Netgear orbi light colors because each colors has different meaning from classic Netegar routers.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 58
1 Kommentar
Hi @cipewe,
What is the model number of the Orbi router?
von jayeff
