Zum Hauptinhalt wechseln
Das Huawei P8 Lite (Modell: ALE-L21) angekündigt im April 2015, verbindet Schönheit mit Schlichtheit. Seine professionellen Kameras ermöglichen es dir, selbst in der düstersten Umgebung natürliche und scharfe Fotos zu machen. Der Beauty Modus hebt die schönsten Seiten des Eigentümers in jedem Selfie hervor.
111 Fragen Alle anzeigen
Weak GSM signal indoor
After I took my phone in for repair charging block my Huawei P8lite Have Bad signal then it shows Emergency calls only or No Service But at Certain Spots it Finds A little bit Signal in bathroom Only H+ And in town it gets 4g Its signal is very bad... Before I took it in for repair I didn't struggle with the signal it was 100% working... After I took it in for repair the charging block I struggle with the Signal. I did take it back to them they check what's wrong they said they accidently broke my Anthenna /signal Anthenna they show me it is a Small silver thing... They repair it For free they said because they broke it... But Nothing changed.. Still struggling no service or Emergency Calls only... Please I need Help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Take it back. What did the part look like? A tiny ring? Also is it from the bottom or the top of the phone? If it's from the bottom they can fit a complete speaker assembly which has the antenna connection on it. If its from the top they need to solder on a new connector, unless they ripped off the pads in which case they would owe you a new phone.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Estie Botha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 29
