Zum Hauptinhalt wechseln
17" Thin and light gaming laptop 8th Gen Intel 10-20 Series NVIDIA 8-32 GB of RAM 1080p or 4K 60Hz display
2 Fragen Alle anzeigen
Boot loop HELP please
My laptop turns on , shows logo and then when the loading bar is full it turns off and beeps. The weird thing is that it still can go to bios and system assist. It won’t boot to windows. Someone help.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Do you have another working computer?
von
Einen Kommentar hinzufügen
1 Antwort
Hi,
Try starting the laptop in safe mode (see Method #2) and check if it does get into safe mode OK or if not then try a Startup Repair.
If it gets into safe mode OK then most likely there is a driver problem as only generic Windows drivers are loaded in safe mode and not drivers specific to the hardware in the laptop.
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
If you have to try a Startup repair, do not select the Reset this PC option because if you select the wrong option after this you can erase all your data as Windows will be reinstalled.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ed Padilla wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 433
