Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
Can I use a ipad 2 battery on ipad 3
I have ipad 3rd gen it's battery is dead
I also have 2nd gen ipad can i use the battery on 2nd gen for the 3rd gen.will it work properly
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Unfortunately, you're off by one generation. The batteries for the 2nd and 3rd gen iPads have different part numbers, connectors, voltage, form factor, and vastly different mAh ratings. The 3rd and 4th gen iPads do use the same battery, but the 2nd and 3rd aren't interchangeable.
Gold star for attempted reuse, though!
Here's a link to iFixit's battery that's made for your 3rd gen.
iPad 3/4 Battery - iFixit Store
Good luck with your repair!
Replace a battery compatible with 3rd and 4th Gen iPad models A1416, A1430, A1403, A1458, A1459, A1460. Part #616-0593, 616-0592. Battery model A1389. 42.5 Watt Hours (Wh). 3.7 Volts (V). Bild
Produkt
iPad 3/4 Battery
$39.99
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Z17 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 560
