Zum Hauptinhalt wechseln
Dell Latitude E7270 12.5 inch laptop
4 Fragen Alle anzeigen
Ethernet jack replacement, has more than 8 pins?
Hi,
My ethernet jack on my laptop is not working properly and only works when I push at a certain angle, I opened it up to see what the port looks like and see if I can find a replacement that will fit.
Here is the photo of the jacky as you can see it has extra pins apart from the 8 standard rj45 connector pins.
Does anyone know what these are for or are they just for support? Thanks
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I saw that listing on aliexpress too, from the photos the closest one that match is 32 or 35.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
The extra connections may be for the LED lights next to the RJ45 jack if it has any.
Here's a schematic of the RJ45 setup from a Dell 7470 ( LA-461P motherboard - I couldn't find a free schematic for a 7270 LA-451P motherboard ) which shows the connections. Hopefully they are similar.
The part number is 130456-511 but I had no joy when searching for it either.
(click on image to enlarge)
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks that makes sense, how can i forget the LEDs would need connections too! I found some that might fit but without the LED legs, mentioned in the comments of the original post. If it doesn’t i might just have to deal with using a usb ethernet dongle
von
Antwort hinzufügen
Eddy M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 177
