Zum Hauptinhalt wechseln
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
781 Fragen Alle anzeigen
Tony hawk ride skateboard not working
I have an item that I'm not sure if the item can be fixed or not. The item is a physical plastic skateboard accessory for tony hawk ride. I have this game for ps3. The skateboard was bought brand new.
The problem is that the skateboard no longer stays connected to a doggle. As shown by the picutres, I'm not sure if the skateboard can even come apart. There is no disassembly of this on youtube or any guide whatsoever.
My guess would be the circuit board that has all the buttons and the led lights would need to be replaced. It looks like you can take the board apart, but there is probably more screws that are hidden.
When the skateboard works correctly, there is one led light that lights up in red.
The manufacturer doesn't give any information out at all. Ignore the white label in the first picture. The last two show a doggle that the skateboard connects to. The problem is that the skateboard doesn't stay connected to the doggle. The silver cable has an outer rubber part that came off. This would probably be a fire hazard if plugged in.
If I replaced the little circuit board in the last picture, I would probably have to do some soldering. What about covering the silver cable? The outer rubber part came off.
The worst case is I get another skateboard and doggle.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hey, slightly off topic, but did you open up the board itself in the end? If so, how?!
von
Einen Kommentar hinzufügen
1 Antwort
your correct sure indeed u need a new board for the doggle
check them with a test meter they just look wrong
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
You mean for the skateboard? How would I open up the skateboard accessory?
von
the doggle accessory is not allowing u to stay sync to the doggle it could be it needs updating or even that it has a bad board and only 17% of the product line had the problem with the skate-board board so i assume it's the doggle accessory
von
also the skate boards not ment to handle more than 190 lb found that out the hard way being way over that lol just put 2 and 2 and u got it almost
von
I'm not sure if the doggle is to blame or not, since when the doggle was new, the red light would come on and stay on, it would never blink or turn off. The skateboard light would also come on, stay on, it would never blink.
As of now, the doggle light stays on, but the skateboard light doesn't stay on. There's no way to update the doggle. As shown in the picture, the outer rubber part came off, exposing the innner. I haven't used the doggle since because of a fire hazard risk.
von
I added a picture of the circuit board from the skateboard receiver. If the board has gone bad, I would need to find a replacement and cover up the silver cable.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Justin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 532
